My Z has a problem when I first start it. It starts right up & it seems fine until you drive it. It has dead spots almost like your shutting off the key. If you let go of throttle it idles fine. You throttle it again it shuts down. If you push in the clutch it will rev up. Once it warms up it is fine. It has a new wiring harness, Coolant sensor, Checked the tps switch it has 7 ohms open. timing at 15 degrees. No codes. All new vacuum lines. pcv valves. Any suggestions?
Cold running problem. Can anyone help? - sunroof44607:44:43 06/02/12
